power handling question
That makes sense if you have something like a Motorola piezo tweeter .
i suggest you to move in the opposite direction ,which is having maximum efficiency ,and not throwing useful energy in a resistor that would transform it into heat . Also ,putting a resistor in parallel with a driver ,would mimic the effect of an Helmholtz resonator ...:confused::rolleyes:
which is not the case of a tweeter , even if some have a back chamber ...
