Power Devices for old Power Amplifier's from MOSPEC - Quality Standart like "ON" ?
a member said that hey are poor quality devices...
a pity , as they pretend to produce the
famed 2sa1302/2sc3281...
anyway, there s plentyfull of good devices from
the sanken, toshiba, or even fairchild and onsemi
that have good guaranted performances...
I just found this thread.
I have using some C2922/A1216 from MOSPEC about 8years ago, and doing some short test. I am only blowing two of them, may be enough for the test. As I remember, it is tougher than the spec on datasheet. Also has much lower Rbe, that indicates more electron mobility and heavier. They has the same numbering but cannot be used as replacement, too much differences, too slow and heavy compared to SANKEN, but may tougher when without heatsink isolator.
