Power cords and plugs (split from Beyond Ariel)
You may be surprised by how many people on here will deny the possibility of, say, a line cord having an effect at all, therefore not seeing the possible technical issues. I definitely agree with the proposition that changing line cords is no solution and that $3,000.00 cords are ludicrous, but to a well heeled audiophile without technical chops, who is to say what he hears as an improvement is not worth the money? You may as well be talking an alien tongue as try to convince him it would be better if he ironed out the technical flaws in his gear, he can't, so won't.
You are correct.
There is no need to pay thousands, or many hundreds, of dollars for superb-sounding power cords.
Sorry, the sites of these suppliers do not have sufficient information.
I chose those cable empirically, not because of any technical data.
I suggest you ask for more if you are serious about having more organized approach on your selection.
I have no idea what technical data will predict the sonic impact cables may have.
Up to now, it seems you are just doing random mix and matches.
Indeed.
This costs way too much for the results you can get.
It did cost me much less than an expansive commercial power cord which I tried on my system. I tried it, found it unsuitable and didn't purchase it.
The list of necessary information is the minimum to make a preliminary list.
Again, I have no idea what technical data will predict the sonic impact cables may have.
One reason I have intentionally left the power cords out of our development effort is that the cost and return in terms of audio improvement is not as worth the effort with current state of technology.
As a manufacturer, you are probably correct.
As a consumer, I have different considerations.
I don't need to look at anything until someone proves that there is an audible effect to the actions in question. Just to refresh, here's the op:
Apparently you look for proof by the words of others.
If you want to know the factual truth of the matter, try and see (hear) for yourself.
I’d love to hear an explanation for the above phenomenon.
I don't have an explanation. I only have empirical results.
If you want words of others, I'm not the one who will supply them. If you want to know the factual truth of the matter, try and see (hear) for yourself.
Pretty sure I know where I'd put money.
That's excellent.
Have there been properly controlled tests done on the audibility of power cords?
As for the balance of your post, had you taken the opportunity to look at the material I mentioned and had a little poke around at JNeutron's posts on the topic on this and other forums you would know that indeed the effects he demonstrates are in fact understood and acknowledged at least by some. Disturbingly they do not appear to be understood by many of the people who design home audio equipment. However, if you try to look up the literature
under "power cords" you will probably draw a blank. Most home audio equipment with bonded safety grounds will suffer problems due to ground loops. Tuning those loops may well have an audible impact, though fixing the problem is a better idea.
That is correct.
I admit I can't prove audibility to you, but I am not at all surprised that people claim to hear differences in sound when changing power cords.
Why should anyone try to prove anything to someone else, unless he is trying to sell something?
Trouble with that concept, is hearing "something" that no-one told them to expect.
Indeed.
In my case, when I made those experiments, I didn't have a clue what to expect.
On top of that, I tried some interconnect cables and power cords that I thought would be excellent, due to the raving reviews they received, and found out I didn't like their sonic signature.
The placebo effect and prior expectations as an 'explanation' are only excuses for those who have a firm belief on the matter. They believe cables cannot possibly make sonic differences, so they find excuses to confirm their belief and dismiss any evidence that may contradict their belief.
So then, your here to tell people the effect is real because you say you hear it, but you keep it a secret? Hmmm. My first impression would be that you are afraid that the scientific people here would punch huge holes in your methodology. I suspect they would be correct.
So far no one asked me how I did the tests.
I'm amused by the social phenomenon that people draw conclusions based on wrong guesses about the way I did the tests.
I'll skip detailing the tests procedure. Those who are convinced that cables cannot possibly make sonic differences will find flaws in any procedure, so there is no use.
I've not seen any guesses about how you did the tests.
I am amused that someone would come into a discussion forum with specific unsubstantiated test results, and refuse to discuss the test method....in a discussion forum.
Having seen your posts over the years, it was my expectation that you would refuse to detail your test procedure. I also expected that you would use as an excuse... that others would find flaws in your procedure.
As to a power cord causing an audible change, I have proven that it does happen, and given details. So your argument that "those who are convinced"... holds no water with me.
jn
Let's see.
How does one know what causes this mysterious "sonic signature?"
Could it be the room, the driver, the horn, the wire, the amp, the preamp, the source, the recording microphone, the wire, the mike preamp, the mixer, the process of laying it into the format, the dinner you ate? LOL
Can't draw that conclusion... as it doesn't account for possible 2 factor variable interactions; i.e. power cord + humidity in tandem affecting the sound; or maybe a Domino's Pizza delivery drone flew over while you were listening?
Surely if changing a power cord makes such a difference, then it is easy to make measurement recordings for each condition that capture these differences. These could then be posted for people to do ABX testing with.
Power cords and interconnects are regular fodder for hand waving conjecture. Few step up to the plate with valid data.
Snake oil salesmen shy into shadows at specter of blind testing.
No need for house guests.
Just post some blindly believable data.
So you agree that reality could be very different than what you believe? For example, maybe there actually isn't a difference in power cords.
Or does it only apply to other people?
Its because the claims lack credibility and are given without even a shred of supporting evidence except the - pointless as you pointed out - subjective beliefs of the listeners. Show me a valid blind test where listeners could hear the cable (or whatever) and I will listen very closely. Spew unsubstantiated biased opinions and I'm not going to take it seriously.
So I am not "revolting", I am "revolted".
The above states explicitly that it is only "subjective beliefs of the listeners".
This is nothing other than wrong guess.
It doesn't make me revolt - it makes me laugh.
The reason for the change in the "sonic signature" is a very well understood phenomenon. Its called confirmation bias.
Unfortunately, to accept this (or to even test if it is in play) may very well shake some deep rooted beliefs.
Are you prepared to be shaken?
The above states explicitly that it is only "confirmation bias ".
Yes, confirmation bias is very well understood and proven. It is not a belief, its a reality. We are all subject to it and even when we think we are controlling for it or aware of it, we are still captive to it.
There is also the related placebo effect. It applies to cables just as much as it applies to medicine.
[/I]The use of the word "prominent" implies that the effect is reasonably obvious. The OP underscores this by claiming that its not just him, others hear the same thing.
If this is the case, you'd expect this effect to be commonly understood and captured in the literature.
It's not. Any audible effect of power cords (when appropriately tested) has been found to be so minor that, if it exists at all, the chance of identifying it is the same as guessing.
Which leaves us with just three options (that I can identify):
1 - the OP and his others are an exceptional group with listening abilities well beyond those of the standard human and are identifying a phenomenon that, typically, others cannot.
2 - the known science on the subject of human perception and the issues around bias, expectation, and the other mind tricks we play on ourselves in all areas of endevour.
3 - the known science around electrical engineering which would identify that either the OP's audio equipment is seriously deficient (ie unstable) and is unable to handle very minor changes in power supply conditions and/or the selected power cords are so seriously deficient in design and execution that a competent system is unable to compensate for the shortcomings.
yeah I looked. Doesn't change the onus of proof. There is no reliable evidence that an audible effect exists. Until that, there is no point postulating an electrical cause.
If something beyond "I sat around with some friends, swapped cables in and out and we sure heard something" comes along, then I'd be as interested as the next guy to understand why it occurs.
But on current evidence, the explanation already exists. Its in your mind. Why is this so difficult to accept?
So, people, without knowing anything about the way I concluded about the sonic differences, decided that:
"It can be anything other than the power cords themselves",
"power cord + humidity in tandem affecting the sound; or maybe a Domino's Pizza delivery drone flew over while you were listening",
"Power cords and interconnects are regular fodder for hand waving conjecture",
"So you agree that reality could be very different than what you believe? For example, maybe there actually isn't a difference in power cords.",
"subjective beliefs of the listeners",
"The reason for the change in the "sonic signature" is a very well understood phenomenon. Its called confirmation bias.",
"Yes, confirmation bias is very well understood and proven. It is not a belief, its a reality. We are all subject to it and even when we think we are controlling for it or aware of it, we are still captive to it.",
"There is also the related placebo effect. It applies to cables just as much as it applies to medicine.",
"Any audible effect of power cords (when appropriately tested) has been found to be so minor that, if it exists at all, the chance of identifying it is the same as guessing.",
"the known science on the subject of human perception and the issues around bias, expectation, and the other mind tricks we play on ourselves in all areas of endevour.",
"the known science around electrical engineering which would identify that either the OP's audio equipment is seriously deficient (ie unstable) and is unable to handle very minor changes in power supply conditions and/or the selected power cords are so seriously deficient in design and execution that a competent system is unable to compensate for the shortcomings.".
All the above statements are based on wrong guesses about the way I compared various power cords, and/or wring guesses about my sound system.
I didn't report the results of a scientific study, I shared my experience.
However stating that my experience is "hand waving conjecture", or "subjective beliefs of the listeners" or "confirmation bias", or "placebo effect" – without knowing how I did it is nothing other than prejudice of those making those statements.
All the technical data you provide don't change even an iota in the above prejudices. They wouldn't let themselves be confused by the facts.
Me neither, I would quite like to know what test procedure was used.
What counts here, more than the actual procedure, is learning to 'trust ones' ears'.
It is a very long process and I don't see any way I can teach others how to do it.
Possibly, some basic steps are:
It is essential to have a very good and detailed familiarity with ones' sound system and all its' nuances.
With many changes to the system, both minor and major changes, it is necessary to be able to note what effect on the sound various changes have.
It is essential to check ones' audible impressions against prior expectations.
It is necessary that at times a friend will change certain component, say a cable, without one knowing what was changed – and noting the audible differences, or lack off. It is necessary to verify if and when there are differences in the subjective impression when knowing what was changed vs. when not knowing what was changed.
One would know that one can 'trust ones' ears' once one may have the very same subjective impressions when knowing what was changed and when not knowing what was changed.
The bottom line is that one need to be able to 'trust ones' ears' completely.
Without 'trusting your ears', no procedure is good enough.
Once you'd 'trust your ears', you'd know what procedures are necessary, or what procedures are working for you.
Let me share with you a true story that was a step for me in getting to 'trust my ears'.
At one point I installed an isolation transformer to the system and found that it improved the SQ.
On the next step I replaced my existing power-splitting box with another one, which I borrowed from a local dealer for testing. Following that I noted two simultaneous phenomena. On one hand, some aspects of the SQ improved, while on the other hand I noted an irritating sound in the mid-high frequencies. I was going to return the splitting box to the dealer, but he asked me not to hurry and to check it a while longer. So I did some tubes rolling and found out that one of three tubes in my preamp was distorting. So I checked it again with the previous splitting box. Low and behold, that distortion was there, though barely noticed. With the new splitting box (along with the isolation transformer), my system became much more transparent than before, thus that distortion became much more apparent. The end result was that I replaced the faulty tube and purchased that splitting box.
The above is but one incident, out of few, that showed me that I can trust my ears.
When others who don't know me claim that it's 'placebo effect', or that it's 'only in my head' – it amuses me. It amuses me to note their prejudice.
About the heated debates in this thread.
I do know that my subjective evaluations aren't going to convince anyone. I'm not into trying to convince anyone about anything. Yet I'm amused to encounter again certain prejudices.
in the absence of any data at all, and your lack of willingness (or ability) to provide any, the hypotheses (not guesses) put forward are entirely appropriate.
My responses are based on much more data and listening testing over more years by more people that I could possibly provide as an individual. Yours is based on... well, actually we don't know what its based on. 151 posts in and you have still to give even the most cursory of outlines of your test methodology.
You claim that you are rational and base all your decisions on "empirical" evidence. Wiki isn't the greatest source of all time, but at least its readable. Here's what it says about empirical evidence and testing:
Empirical evidence - Wikipedia, the free encyclopedia
You'll note that its not a replacement for scientific method. The same scientific method that I and others have broadly relied on.
You appear to think it means what ever you observe is true. Thats not empirical evidence, thats egomania. Certainly, you have not provided the evidence which would support another interpretation.
So, far from being confused by facts, we are seeking them.
Opportunity for you then - put up. Prove me wrong.
I don't always agree with jneutron, but he does seek to provide technical arguments and data to support his views. I listen to him, and consider what he says. Facts are what change my mind.
What someone believes themselves able to hear under unspecified conditions is not a fact.
I shared my personal evaluations.
I seek not technical arguments concerning power cords and other cables.
I don't intend to enter any technical arguments concerning power cords and other cables.
Yet, I cannot and I have no wish to stop anyone else from discussing whatever they may wish. Those who want to discuss technical arguments are welcomed to do so. I'm not going to participate in it.
My comments so far were about the absurdity of those guessing wrongly about what I did and how I did it.
(Personal notes,
1. To the best of my evaluation, no technical arguments are going to move anyone participating in this thread from ones' present stand on the matter. Therefore I see no point in doing so.
2. AFAIK, existing technical explanations fail to cover all aspects of cables' influence on perceived sound.)
You need to re-evaluate. Technical arguments have been presented, some people are quite accepting of the arguments, and more importantly, the technical arguments are testable. You refuse that.
How would you know? You state outright that you ignore the technical arguments.
jn
