Power Amplifier Circuit Topology according AD846
Are there commercial products on the market or are there diy projects like discrete opamps, where this topology is in use?
Most interesting feature is the fact, that here (in the inverted mode) the signal pad goes in to the emitters - thus no parasitic capacitances have any influence.
Thank you for advices.
Concerning the AD846 there are follow threads here on diyaudio:
http://www.diyaudio.com/forums/solid-state/5807-ad-846-ther-better-sounding-opamp-out-there.html
http://www.diyaudio.com/forums/digital-line-level/118303-ad-846-replacement.html
844 works on same idea - current conveyers into diamond buffer. Just a bit more sophisticated conveyers.
Thank you. Maybe Jan Didden's current Conveyer power amplifier project for German's Magazine "ELEKTOR" (PAX-AMP?) is such a topology in a discrete version. But I am nut sure. Who can upload the article?
Here on diyaudio I have found this:
http://www.diyaudio.com/forums/digital-source/217057-inverting-current-conveyor-approach.html
http://www.diyaudio.com/forums/analog-line-level/223835-current-conveyor-voltage-amplifier.html
http://www.diyaudio.com/forums/digital-source/218038-insense-current-conveyor.html
http://www.diyaudio.com/forums/soli...ack-called-pax-what-about-vitus-ss-101-a.html
