That was quick, but I disagree. Im sure rod would love the fact
that his material was being used to save DIY'ers from fire
and destruction .
If I went around DIYaudio all day(100's of items and links)
and complained about posted material and it's possible
intellectual property infractions my fingers would be shot.
We do not post here to sell , profit , or make any personal gain.
If anything ESP sound received free advertising.
P.S. If you read his site he explains why there are no resistor values.. The schema in question was put in the public domain
for the same reason I posted it.. Instruction and discussion!!
At least here in the US most schematics I see posted in DIY land
are covered by copyright law ...SO we are all guilty..😀
and destruction .
The schematic is copyrighted and not in the public domain, i.e., it's RE's property. If it appears on his website, it's probably legal to post it here (with appropriate attribution) by Fair Use, but if he has stated that he'd prefer that it just be linked to, good manners would be to do that. Or make your own drawing of the circuit.
RE's site is a gold mine of great info, and I think his contributions to audio hobbyists earn him a bit of deference.
Disclaimers: I am not a lawyer. These are just my personal opinions.
We'll put in the link soon, just none of us have time right now. Although this will surprise some, we don't like to annoy people who contribute to our interests. 😉
megajocke said:It usually means that both halves are 5 amps capable.
It should be easy to verify by cheking the size of the transformer, there will be a obvious size difference between a 500VA and a 250VA transformer 🙂
Right now I have a 30 lbs UI-core 2000VA transformer on my desk that needs rewinding to provide more useful outputs than a low (okay, it's 300VA or so) power 42VCT and almost all power on a 80V non center-tapped secondary... 😀
thanks megajoke
over a VERY minor issue I must rethink my position.
One could be fully anal and go after each and every possible
infringement pertaining to intellectual property rights here at
DIYaudio but that would be the same as Mcdonald's
suggesting the takedown of the hypothetical "McAmp".
When I posted that schematic I had the choice of the FULL
version, his website version and a drawing.. so I was aware
of its source and explained on my post it's place of origion.
If this is my last post on DIYaudio ,so be it. I've pirated EVERY
bit of info off of every last link of the site so there is not much
more raw info I need anymore. (Over 300 full copyrighted
schematics). I am not overreacting, but I feel this
"browbeating" will cramp my style (I'll be scared to post).
What a shame...
Good day ,OS
browbeating wrath
no wonder i have hard follow some topics
when those speaking english/american/australian
have difficulties to communicate
thanks to John Steinbeck, the athor of 'Grapes of Wrath' ( 'Vredens Druvor' in swedish )
i at least know this word
and I can say our moderators at www.diyaudio.com
do not get angry too easy, these days
they have the experience gained to know there is not much benefit in getting angry
not for things like one or two forums posts
when there is a world out there where people kill eachother
in plenty every day
these guys keeping us within limits
also know, that is often enough warning sign,
that one moderator post one post .. without words
to make us shape up to better standard
the standard we want
Lineup - regards to all readers
in plenty every day
ok... I've attached an edited schematic showing what I think should be done with the protection diodes.... is this right?... seems to make sense to me...
Maximum Vgs on the IRFP450's is 20volts... so I have got a 15v zener, and the diode (both of which can handle 10A for the few ms before the fuse blows) ready to install. Before I go and install it, just want someone to say its the right (or wrong) way of doing it.
Cheers....
Cheers....
what about a 6V to 10V Zener on each FET direct G to S, i.e. after the gate resistors?
Does this extra capacitance affect the HF performance of the circuit?
maybe... but the reason I put the diodes before the gate resistors was so that fault current wasn't flowing through the 27ohm resistors... they would burn quick...
I'm mainly concerned about the setup I have on the FETs connected to -Vcc. Is that setup correct? Vgs is measured from negative source voltage. And would 15V zeners provide enough protection? (that would mean at fault Vgs would make it to about 15.8 volts)
hi quasi
i cannot find find 50 ohm trimpot/preset for actrk600 can
i use 100 ohm instead one more thing what should i use a diode or a 82 ohm resistor for T4. the board is almost complete
thanks in advance
thanks in advance
AndrewT said:a 100r // 100ohm pot will give the same adjustment sensitivity as a 50ohm pot
thanks
andrewT
posting my pics soon
ravslanka said:hi quasi
thanks in advance
As Andrew has mentioned because this is a muliturn trimpot the adjustment sensitivity will be ok. It will be slightly more sesitive so if you are worried about it put a 56 ohm resistor in parallel with it. Use a diode into the base of T4.
Cheers
Quasi
- Power amp under development
