I am thinking of building a power amp using moduls from SKA-Audio in Australia. The kit I want to build will be a dual mono design based around the GB300D with dual psu's and possible dual 500VA transformers, not decided on this bit yet.
Trying to find a suitable case to house this little lot that is going to look good in my rack and not cost a bomb. I have found some on ebay that fit the first criteria but not the cost part;
Hi End Power amplifier Chassis/Case, Full Aluminum /MK2 on eBay (end time 28-Mar-10 04:03:07 BST)
Hi End DIY Audio Power amplifier Chassis/Case /A200 on eBay (end time 31-Mar-10 01:15:36 BST)
Others I have seen mentioned a lot are;
modushop.biz
These look ok but not great??
Any others out there that are recommended?
modushop.biz
Check in EBAY by searching using the following description "HiFi DIY Audio amp chassis table top enclosure 20-12124" Clic in the description then clic in the antek store. It will take you to the store. They have different styles and sizes with the right prices.
