Power Acoustik Overdrive 7500
amp has a few snapped power supply fets replaced them. Then I took out the rectifiers and powered it up and a 2x(q3) kept heating up on the same side. Pulled it and noticed 9 volts sitting on pad 1 of q4 (2t)and pad 2 of q16 (2x). On the working side of the amp a resistor pulls the voltage down going to them. On this side it’s not pulling it down. It’s the same before and after r36. And the 9 volts I’m reading is what’s coming off the voltage regulator. I pulled the resistor and the voltage went away. Tested the resistor and its good. I’m lost. Only thing I can e see to pull that down is the resistor that seems to be good. Any help appreciated 9276463D-33C8-49D1-A7D6-F06FDD7137B9.jpegC0C1CDC5-01A9-4E7C-AC6E-11C60E9AF018.jpegC0C1CDC5-01A9-4E7C-AC6E-11C60E9AF018.jpeg0AC6B354-E5EF-41A4-B69C-20F07F9D60C6.jpegB34E54D6-69E2-47EE-9A50-96E295617B86.jpeg
It looks like it’s 4 on that schematic and only 3 on this amp. I’m probably looking at it wrong. Good drive on the writing side and on the bad side I have drive that looks good on one side of r40 and funky on the other
