Power acoustik amp problems
I have a power acoustik lt-980 2. I wired it in my car hooked up the subs and nothing. I got them used and the guy showed me it was good. I suspected my RCA jacks, but checked them and they were good and also tried a good head unit that worked with an amp. The amp goes into protection mode as soon as I touch the RCA wires to the amp, and when I disconnect the RCA wire the light goes out. I have no idea what is up and really need help. Thanks so much.
Im not sure. the batt had 11v and there was 3 at the amp. But when oi touched the black probe to the frame and red on the + batt. I Only had like 3 volts also. so then I checked the voltage of the + wire grounding on the neg batt terminal and again less than 5
v
Im not sure. the batt had 11v and there was 3 at the amp. But when oi touched the black probe to the frame and red on the + batt. I Only had like 3 volts also. so then I checked the voltage of the + wire grounding on the neg batt terminal and again less than 5v
