Potentiometer problem on an Onkyo A-8130 amp
Hello,
I would like to change a potentiometer with four pins, dual channel. When i just replace it with a three pin potmeter, it doesn´t work.
Because, as you can see, this volume knob is connected to the loudness, balance and cd direct button.
To complicated for me, i guess, but maybe some one can give me a hint where to start?
I appreciate any help, thank you in advance!
I try to repair this Onkyo integrated amp for my neighbor, he is very attached to this amp...
The problem is that after start up, there is no sound on the left channel. I opened the volume pot and noticed that there are cracks in the carbon. I suspect this is the problem, because when you turn up the volume to very loud, the left channel comes in...
Anyone?
