noticed this item on ebay:
diy lcd tv w/ electronics
did a little more research on the item and came up with specs from parent company:
http://www.action.com.tw/acv/LMM104.htm
also noticed same company has higher res panel:
http://www.action.com.tw/acv/LMM121.htm
worth a shot, with all electronics bundled in
checked ebay feedback for seller, seems item does work ok..
nice bit of kit that......
I posted this a while back.... http://www.diyaudio.com/forums/showthread.php?s=&postid=103165#post103165
Anyway it's always good to bring back to people's minds and then maybe someone will take the bold step and order one and share there results.. i would but I'm skint at the moment...lol
LMM 104 lcd specs Post #320
SPECIFICATIONS
LMM-104 TYPE
Color LCD PC/VIDEO Module
DISPLAY SCREEN
SIZE 10.4 inches�i211 �~ 158 mm W�~H)
ELEMENT TFT-LCD 262,144 Color
FORMAT 640(W) �~480(H) Pixels
LCD PANEL
NEC NL6448AC33-18
BACK LIGHT
Two cold cathode fluorescent lamp
POWER SUPPLY
DC 12V
POWER CONSUMPTION
DC 12 V 15W
PC SYSTEM
VGA
VIDEO CLOCK FREQ.
25 MHz min.
SCANNING FREQ.
H : 31.5 KHZ V: 60-70 HZ
VIDEO SYSTEM
Auto NTSC / PAL / SECAM
BRIGHTNESS LEVEL
200 cd/sqm Typical
CONTRAST LEVEL
150 : 1
VIEWING ANGLE
L/R 45/45 Deg. U/D 30/20 Deg.
INPUT TERMINALS
External power jack(DC IN 12V)
Video 1 input jack (RCA type)
Video 2 input jack (RCA type)
Audio 1 R/L jack (RCA type)
Audio 2 R/L jack (RCA type)
PC input (D-SUB 15 pin)
OPERATION TEMPERATURE
5�Ž ~ 40�Ž
STORAGE TEMPERATURE
�|20�Ž ~ �{60�Ž
DIMENSIONS
PANEL 243 �~ 185�~ 11 mm (W�~H�~D)
DRIVER BOARD 190 �~ 120 �~ 35 mm (W�~H�~D)
INVERTER BOARD 100�~25�~10 mm (W�~H�~D)
WEIGHT
0.7 KG
cheers,
BRF.
SPECIFICATIONS
LMM-104 TYPE
DISPLAY SCREEN
LCD PANEL
NEC NL6448AC33-18
BACK LIGHT
POWER SUPPLY
DC 12V
POWER CONSUMPTION
DC 12 V 15W
PC SYSTEM
VGA
VIDEO CLOCK FREQ.
25 MHz min.
SCANNING FREQ.
VIDEO SYSTEM
BRIGHTNESS LEVEL
200 cd/sqm Typical
CONTRAST LEVEL
150 : 1
VIEWING ANGLE
INPUT TERMINALS
5�Ž ~ 40�Ž
STORAGE TEMPERATURE
�|20�Ž ~ �{60�Ž
DIMENSIONS
WEIGHT
0.7 KG
cheers,
BRF.
compared to what qa-1500s or nviews are going now, i think it's pretty competitive. rmember it has a tv tuner built in. anyways, there is an ice cream flavor for everyone.
