Since you only have 8 Ohm output taps on each amplifier, then . . .
Get Two 8 Ohm resistors.
Two 8 Ohm resistors in parallel = 4 Ohms
Two 8 Ohm resistors in series = 16 Ohms
Try 5.6Vrms with 8 Ohm load, '3.5k', then '5k' amplifier.
Then change the load on each amplifier to 4 Ohms, then to 16 Ohms.
Next, 8Vrms with 8 Ohm load, '3.5k', then '5k" amplifier.
You will see the change of the sine wave shape at the output.
Many "8" Ohm loudspeakers impedance will vary from 4 Ohms to 16 Ohms, depending on the frequency.
