Position of Iron in Can of HK Citation II Output Transformers
Hi, I was wondering if anybody knew the position of the iron of the HK Citation 2 output transformers within their cans? Is the iron horizontal or vertical mounted? If they are vertical mounted, which way are the laminations positioned; parallel to the long side of the can or the shorter side?
Thanks in advance...
Daniel
