Portable bass amp idea
Still working on this but only as a speaker cab. I discovered that the suitcase was cracked in one spot so I've glued it. I found a wire basket at the thrift store for 33 cents that I cut out the bottom of fro the grille. Also picked up some half inch foam which I will line the inside using short screws/nuts/washers although the washers I'm making by cutting up a flexible floor tile, 49 cents at Home Depot. So the biggest outlay was the foam at $11. I will test it first using the Smokey Amp, then maybe add a line out to my Micro Cube.
Here's a guy with the right idea
The Velux Suitcase Guitar Amp
He has quite a few designs if you can log in to fb
Acme Widgets
