Port calculator
there are plenty of programs. I like others on this forum like WinISD. Get it for free at http://www.linearteam.dk/
The formula is :
BassAwdyO said:Four 1220w's. Those are the 12" reference subs with DVCs that look like the Kappa perfects arent they? For car I'd suggest at least 1 cubic foot per sub, and tuning around 30hz if we're talking about the same speaker.
Do you have the T/S parameters
yes those are the subs that i have ... what is T/S parameters ? you say that i need 1 cubic foot pet sub so thats 4 cubic foot what is that in inches ? and how do i know what size of a port is 30hz ?
well you said you have 16x35x25inches which will give you around 8 cubic feet which should be pleanty.
Is this going in a car or house? For car I'd almost suggest sealed box because you're going to get a big boost from cabin gain and you really wont need a port at all(unless you're going for SPL) For home ported should work out nicely and you can tune between 20 and 30hz to your own tastes.
Tell me exactly what you want and I'll be able to give my best opinion. I used to own a pair of those subs. I ran them in 10cubic feet tuned to 20hz for HT and it wasnt a bad setup. Although now I have a Tumult in 6 cubic feet which goes down to 10hz and blows those subs out of the water!
Basic vent calculator on my website
http://www.readresearch.co.uk click on the 'utilities' link.
BassAwdyO said:well you said you have 16x35x25inches which will give you around 8 cubic feet which should be pleanty.
this is going in to a car ... now i dont know what to tune it to 20 or 30hz ? u tell me .. or just go sealed ? if its sealed how big of a box do i need then ?
Go sealed. Use a box between 4-8 cubic feet. Anywhere in that range should work fine. I'd suggest going towards the larger end, but it wont make an incredable difference. Make sure when you build the enclosure that there are no air leaks. You can add acoustic stuffing or fiberglass insulation too if you have some handy.
BassAwdyO said:You can add acoustic stuffing or fiberglass insulation too if you have some handy.
how much of fiberglass do i need ?
Here's the 1220w specification. 1220W is a single voice coil 12" sub.
Recommended volume for sealed enclosure is 1.25 cubic feet per driver. Larger box produces deeper bass, but makes it less tight (has greater group delay properly speaking).
I've recently have built a sealed enclosure with two Infinity Reference 1030w drivers and they sound ok. Just make sure your amplifier(s) match the sum of RMS power ratings of your subs and it will be loud.
1" on all walls except the one on which subs are mounted on.
Into a minivan or SUV? That's a large box you are going to have. Car size affects the way sub sounds (cabin gain / transfer function), if you want flat frequency response( same loudness for different tones) you need to take car size into account when designing sub enclosure, especially a sealed one.
boris333 said:what kind of a fiberglass do i need there are two kinds cotton and solid type .. the guy at the store tells me that i need the solid one ? is this correct ? this is in a hatchback car .. the box size is now 30x25x16 ..
If you want to just line the walls get the solid type (compressed I assume?) if you want to fill the enclosure (ie-most of the airspace is occupied by fibreglass) use the cotton type.
Basically, filled is better for pure SQ, un-filled is better for max volume (will be around 3db louder at resonance un-filled)
Try it both ways, use what sounds best to you.
- Subwoofers
- Port ?
