Port location on box / Multiple Ports
I'm sure either of those would work okay. What about moving the front one down so that the vertical center is on the gap between the two drivers? For the one in the corner, you'd probably end up quite a bit shorter than simulation, which is a good thing, you just have to check Fb with test tones (or another method) when you're done. You should do that anyway.
How am I supposed to check the Fb with test tones... just playing tones?
Here is the suggested circuitry made by the calculators.
Notice the details of the attenuator and notice the tweeter box.
The tweeter box looks like proposes another circuit for attenuation and it suggests a 22 Ohms/20W resistor to bring down 21 dB.
Also, the folk who said in here that "the piezo is never 108dB" means that this box is probably wrong numbers???
piezos are different from conventional tweeters:
Frugal-phile | Piezo Tweeter Crossovers | J Risch
Yes, I realize that the the text you are proposing to be read has the same circuit of the one printed on the tweeter's box.
So I just ignore the DIY tweeter attenuator? I am not sure as to which related detail you are telling me this. Should I ignore the crossover circuit or the attenuator circuit and follow the piezo scheme?
