Port length alteration?
I am building a FF225WK which calls for a port of 65mm diameter and 190mm length.
I get 94mm length (WinISD) for a single 65mm dia. port, tuned to 50Hz. The 190mm length came off the Fostex recommended bass reflex tuning right? That would be for a 28l box, tuned to 39Hz.
Can I use 2 ports of 35mm and keep the same length?
They would be ~56mm long for two.
jeff
Here's the graph showing both fr curves, red is the Fostex tuning (~39Hz) and the yellow is mine (~50Hz). Sorry for the lousy image quality.
jeff
