Poor Serbian Man Lightspeed packages
yes, is hypex, I can bypass the volume if need...
the ldr work fine with 50k input power amp ? not cut all vol ?
well - I'm pretty sure that lowest margin is ~75K ; but you can easily alter that on tube amp , taking care also that you don't have heavy capacity cables between LDRs and amp
or you can populate entire 4 buffer section , hat way having 2 stereo unbalanced buffers , so each amp will have own buffer
Hi Zen Mod,
Just wondering if you received my order for the boards and parts.
Do you think it is advisable to replace the pots on the buffer boards with trimmed resistors? I don't see the point in eliminating the pot and then adding one in the buffer that is in line with the signal. What do you think?
Thanks,
Bill
Hi Zen Mod,
Thanks,
Bill
yes - I received your e-mail ...... but I'm fighting these days with day's work , keeping Baby Diya tidy , and answering PMs here and Baby Diya ........
yes - that's usual praxis - put trimpot there - let it cook for a while , set offset (if any) , measure trimpot (both sides) and put two fixed resistors instead
I'll answer (the other way ) to you little later
