PO89ZB PCB's
Joined 2001
I had a small run of Mark Johnson's "inline DC filter for SMPS wall warts" PCBs made. Thread is in "Analog Line Level". I'm keeping a small stash for myself and I will distribute the rest to those that want them, no charge. Limit 2, and US only please to keep this real simple. PM me your mailing address (and quantity- one or two), and I will throw them in an envelope with a stamp. For inspiration, here is my own example showing two in series (not necessary though, a single works great).
Reactions: manniraj and codyt
I tried to send you a PM but because I'm so new to the site, I can't PM you. Actually purchased 2 of these thinking they were completed 🙁 I would like to try these out one on a Wiim mini and one on a Modified Aiyma A07 with a 36v 10a power supply. Will gladly send you the new in-pack ones for your time.
What was the question exactly? Just trying to understand the situation here. You purchased two kits from the DiyAudio Store and are unable to solder the parts on the boards yourself? Soldering isn't really too difficult once you get the hang of it, there's probably tons of videos about how to do it on the internet. With these filter boards, you will want a wide heavy chisel tip on your iron for the ground connections where the wires connect. You are wanting to mail the kits to me and have me build them up for you? I could probably do it but I have half a dozen projects going on at the same time right now...
