PMC TB2S+ driver replacement, needs advice
Hi guys!
I guess I found quite identical replacement for a Vifa M17WG-09-08 LF driver.
Here it is: Seas H1217-08 CA18RLY
It's data looks very identical to the original one: Vifa M17WG-09-08, datasheet 2, excluding a little larger OD and 6 holes, but it is not such critical and can be solved.
I'm not a speaker guy, I need your advise on this topic. Please, confirm or not this replacement suggestion.
My TB2S+ has a 2kHz crossover frequency by the way.
Thanks!
