The main speakers in my system are full range open baffles assisted by an open baffle subwoofer (20-50Hz). The subwoofer is connected via a passive line level x'over (pllxo) to the output of the amp driving the main speakers.
I have just replaced my chip-amp with the Sonic impact T-amp (WITHOUt connecting the pllxo/sub-amp/sub). The output of the T-amp is "floating" (not connected to ground), which means that I can't just connect the pllxo/sub-amp as this will connect one of the outputs of the T-amp directly to ground.. :-(
Is there a simple solution to this "problem"? I was thinking of creating an arteficial ground by connecting this "arteficial ground" to both output terminal via 2 resistors (e.g. 1-200ohm) - the pllxo would the be connected to positive and "arteficial ground" - will this work? Alternatives?
(I'm working on a buffer which will allow pllxo's to be placed before both the T-amp and sub-amp).
Thank,
Thomas
Thank,
Thomas
That is exactly where the PLLXO (by definition) belongs.which will allow pllxo's to be placed before both the T-amp and sub-amp).
If you include all output/input impedances in your calculations you could try it without any buffer.
http://www.t-linespeakers.org/tech/filters/passiveHLxo.html
Pllxo's work's quite well driven from power amps too.. 🙂
I need a buffer/pre-amp - otherwise the xo freq will change with the volumen setting (?).
Any suggestions for a solution for the "T-amp problem"?
Thomas
Thomas
ThomasS said:Pllxo's work's quite well driven from power amps too.. 🙂
No, you are still getting it wrong, the output of a power amp is not line level, so the "LL" in "PLLXO" is not there. 🙂
So I am even more intrigued, does this mean you have a speaker crossover made up entirely of resistors and capacitors?
😀 "l" is just a less know abbrevaition for "power":
pllxo = passive power level x-over......
It works quite well as the output impedance of the poweramp is low: low imp - > pllxo -> high imp sub amp (like between pre- and power amp). The pllxo is connected to the power amp via a 200ohm resistor.
And yes - a 3rd order consisting of 3 resistors and 3 capacitors - very easy to tailor the response to subwoofer/room - resulting in a flat 20-45Hz response and then a roll-off matching the main speakers.
Draw-backs: high insertion loss (not a real problem) and the need of an extra poweramp (which you would need anyway if you use open baffle subs with chip or T-amps) - so in this particular case there is no real draw-backs 🙂
Thomas
Thomas
