PLH Question R6 P1 HELP!
i've finally got all the bits together to build the PLH amplifier, but just noticed a potential problem.
looking through the circuit diagram, I noticed that P2 and R4 are high wattage types ~3W
but P1 and R6 are just 1/4w how come???
as far as i can see the same current must flow through R6 as R4?
they are the same value ~220 ohm.
actually R6 isn't so much of a problem i have 3w 220 here. but P1?? i found it really hard to get high wattage 500R pots. i only have 2 for P2 (L+R)
have i missed something?
I've just re-read that paragraph, it says "most resistors are 1/4w types but I recommend a 3 watt value for R4 and R8 and R9" and "p2 is best chosen as a higher wattage type. you can get by with 2 watts, but 5 watts is preferred."
from this I read that R6 and P1 are 1/4w.
R6 must carry the same current as R4, and they are both ~220 ohms. therefore the same power dissapation????
I built the PLH also, and were a bit puzzled for a while on this also. I finally chose to set fixed resistors instead of using pot on this as I did not intent to play around.
My view on this is that - yes those 1/4W are OK. It is related to AC vs DC operating conditions. For the pot and the related R4 specified for high wattage, they will see rather high current in AC (coming via C2 bootstrap C). While R6 only take the DC portion, so can be at a lower wattage as the bias current of IRF610 is about 10mA only. This is how I see the requirement.
