Please review my cart before I order parts for my PSU!
My plan is to build diyA PSU with monolithic rectifiers and a 600VA 24v transformer.
I think this Mouser cart contains everything I need, minus the transformer and PCB. Please let me know if anything looks off or if I seem to be totally off the rails on my assumptions what I need 😛
Direct cart link: https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=37d2997a84
Scroll "code" section to the right to see quantities and prices
Code:
[FONT="Courier New"][B]Part Number[/B]        | [B]Brand[/B]              | [B]Description[/B]                                                             | [B]Quantity[/B] | [B]Price[/B] | [B]Total[/B]
CL-60              | Amphenol           | Inrush Current Limiters 5A 10ohm Straight leads                         | 3        | $2.06 | $6.18
SLPX183M050H9P3    | Cornell Dubilier   | Aluminum Electrolytic Capacitors - Snap In 18000uF 50V 20% 85C          | 8        | $5.95 | $47.60
KBPC5010-G         | Comchip Technology | Bridge Rectifiers DIODE RECT BRIDGE 50A 1000V                           | 2        | $3.61 | $7.22
CPF322K000FKB14    | Vishay             | Metal Film Resistors - Through Hole 3watts 22Kohms 1%                   | 2        | $1.27 | $2.54
CPF31R0000FKE14    | Vishay             | Metal Film Resistors - Through Hole 3watts 1ohms 1% 100ppm              | 2        | $1.15 | $2.30
TLHG6400           | Vishay             | Standard LEDs - Through Hole Green Tint Diffused                        | 2        | $0.46 | $0.92
CPF3R47000JNB14    | Vishay             | Metal Film Resistors - Through Hole 3watts .47ohms 5%                   | 8        | $1.86 | $14.88
CCF0710K0JKE36     | Vishay             | Metal Film Resistors - Through Hole 1/4watt 10Kohms 5% Rated to 1/2watt | 2        | $0.13 | $0.26
1985852            | Phoenix Contact    | Fixed Terminal Blocks MKDSN 1.5/3 HT                                    | 2        | $1.64 | $6.56
62409-1            | TE Connectivity    | Terminals .250 PCB TAB                                                  | 8        | $0.14 | $1.20
MKP2D031001F00JO00 | WIMA               | Film Capacitors 0.1uF 100 Volts 5%                                      | 2        | $0.66 | $1.32
[B]Total $91.06[/B]
[/FONT]
