Please recommend a desktop fullranger?
Actually laser interferometry may not be able to look at what we need to look at to determine what EnABL does. I'm guessing that a microFlown might be the more appropriate tool -- and to get the most out of it you'd need an anechoic facility, so a milliom bucks would be a budget facility.
dave
Nifty, but it should show up in the holograms just as well and show you the patterns.
I concluded my crude attempts at doping the 125's. Quite successful for a safe only one pair experiment. The "conclusion" from my experiments is that if one wanted one all done up, they should just see you. Quite educational. I would not have given as much weight to the mods had I not dabbled in it a bit myself. The real payoff is in better ability to read OEM data sheets and to know how to buy a driver that does not need to be fixed up. That is the path I intend to stay on. Love that reed paper Seas.....
frugal-phile™
Joined 2001
Laser interferometry lets you look at the cone. MicroFlown looks at the air being driven by the cone, they do no show the same things.
I saw you post that you were going to take them over to Doug's to try in his cab. Yesterday i just finished up a colour matched set for our proto Fonken125T which will free up a set. I thot i might ask if he'd like to borrow the spare set (me knowing that it would give you a chance to evaluate them too) -- i've not had a chance to contact him about that yet (Hey Dougie!!!)
dave
The Truth Is
I had a head start :D
Second construction pic.
Cut length for backs and sides at same time - the box self alines square (because of the "triangle") for glue/clamping.
This is a dry fit; cork next, then glue/clamp up on corner of work bench.
If two-way is not prohibited then maybe a TB W3-1723 coaxial speaker in small BR...
Max
You can play a coaxial really loud without scrambling/degrading/shaking the treble with cone movement/excursion. With a coaxial, the inbuilt tweeter won't be doing any flopping about if you happen to use more than a few watts during exuberant playback. The effort for passive filters doesn't seem to be more difficult than a full range, in some cases. For transparency, we'd just need to avoid RC noise in the crossover by avoiding coaxial that have high LE figures.
Absolutely!...we may have to have a East Coast "Fest" right here in MD.
(or we can van pool to Canada)
The new 125wk's for audition have not arrived; I'm sure the West Coast folks have their hands full right about now.
I'd like to have some folks listen to the pair on post #33, they are sounding very nice. Way bigger sound than they look.
Who dat? Can I play in the sandbox, too? :D
