please help me on digital decoder/splitter
JinMTVT
2004-07-12 2:30 am
MTL
i've been searching for an already built standalone digital sound decoder that would let me setup my next HT as i want it to ( use multiples DCX as xovers and dacs )
I haven't found any chip solution for decoding surround sound digital formats ..is there any good solution out there ? id like my system to be able to accept different signals up to the most recent ones if possible
and then decode and split into the different channels
and output seperate digital signals
anyone has work on this kind of project?
the path i'd like to take for my audio setup :
source ( PC, PS3 blabla ) -> digital output ->
custom or pro decoder - > channel assign - > split ->
DCX ( Xovers + some para) ->analogue output to amps
my setup will be :
2 front loudpseakers with 2 channels each
1 front wall of subs :)
2 side surrounds same as fronts
1 rear center same as fronts/sides
so that is 11 channels of signal
please let me knwo if you guys have any indsight on a product or something i could diy with some help :)
anything will be very appreciate, since i am still at zero point right now
