Please help me create a wider than average pdf
I need to make a document to share, pdf is the common format I think.
I'm using MS Word to create the document. It needs to be about 30 cm wide with minimal margins to fit the images. It took me awhile to figure out how to set the margins that wide in Word, and awhile to figure out how to get rid of the page breaks.
When I try to save the document as pdf, two of the pdf creators I've downloaded do not keep the same page size I have set in Word. It doesn't matter if I choose portrait or landscape, doesn't matter what size paper I choose, it always ends up making the same messed up pdf. The other pdf creator keeps the page size but skews they image, it looks like they are rolling across an old tv screen.
I've been working on this for about 12 hours and can't get anything remotely acceptable.
I prefer not to resize the images, there are over 70 images and they are already small enough.
I am able to get perfect results if I just save the Word document as a web page. Is that a common format to share documents? It seems weird but it works.
Please advise. What am I doing wrong?
Hi, try this with Word, but it works with HTML etc too.
Doxillion Document Converter Software
Download to convert document file formats easily
Doxillion is a multi-format converter and the fastest way to convert DOC, DOCX, PDF, WPS, Word, HTML and other file types.
Convert text documents within minutes of downloading
Quick and easy one-click document convert process
Batch file converter to convert thousands of files
Document Converter Software. Convert Word PDF WPS ODT etc. Free Download
