Hi, I would like to know the value of a Wima cap which has the following markings:
3300
63-
This cap is small (approximately 6mm L x 4mm W x 10mm H) so it's definitely not 3300uF. I guess the "63-" means 63 VDC? At the back of it is a "5" marking which probably means 5%?
Your help is greatly appreciated. Thanks in advance! 🙂
3300
63-
It says right on it , 3300pF 63V 5% ......😀
Oh it's pF, duh. 😛 Any idea what series it is (MKS, MKP, FKP)? Why don't these manufacturers indicate the series on their caps?
Thanks a lot! 🙂
[QUOTE=mtl777; Any idea what series it is (MKS, MKP, FKP)? Why don't these manufacturers indicate the series on their caps?
hello.
has it a green case (with a yellow or red bottom)?........then it is a polypropylene cap (probably mkp).
greets
hello.
greets
mtl777; Any idea what series it is (MKS said:It has a red case. I'm not sure about the bottom because I can't see it -- the cap is still soldered on the board. Most likely it is a yellow bottom.
.......the newer fkp parts are red........see pdf datenblatt (=datasheet).
greets
WIMA | Passive Bauelemente | Kondensatoren | Folien | Radial 85°C |FKP2/3300/63/5
greets
greets
Yeah, based also on this table it must be an FKP2. Thanks a lot! 🙂
- Design & Build
- Parts
- Please help ID Wima cap
