Please help a friend of mine (and me!)
A close friend of mine called me on the phone very excited to be receiving a set of speakers for the cost of shipping.
They came from the original owner; a beautiful set of Wharfedale Mach 7s.
However, we set them up and they emitted NO sound at all. He checked the jumper configuration on the input jacks, and the amplifier. With three separate amps.
These speakers have inputs as follows: one set of spring loaded connections for non-bi-wire option, and two red and two black holes for biwire option.
At this point, I have tried ALL options and the speakers make zero noise from any driver.
Is it possible the resettable tweeter protector is muting the sound?!
As per Wharfedale specs, the jumper makes no difference whether is set to bypass the protector or not.
Thank you
Try a 1.5V battery and momentarily touch it across the terminals (probably need connecting wires). The drivers should move. If not, it is a pull the crossovers out proposition.
Put a multimeter across the driver terminals to check resistance.
Sounds very unlikely that all the driver have blown!
This speaker seems to have some sort of electronics or muting or level connected at the top.
But the old trick is to connect a 1.5V penlight battery across a cone driver on its own, and listen for the crackle of life! Or measure the driver with a £5 multimeter and hope for about 6 ohms DC.
Do not try this with exotic ribbon tweeters, however.
It would do no harm to try that across the input either, before risking an amp.
Edit.I see I'm not the only person who knows this trick, Tromperie. LOL.
