platter is rotating in reverse
Wow didn't realize the responseI got from my REGA running in reverse...lol Since then I had stored the table and was using a Heybrook TT2.
My son saw the REGA and asked about the reverse playing. and wanted to look. Says the whole thing was wired wrong. and the Blue wire had a cold solder joint that came loose. The red was intact but as he noticed wired wrong.
This REGA has a plinth of PLanar2, I replaced old "S" tonearm with REGA RB-220 added a subplatter kit from "TangoSinner" it came with new belts and pully bearing oil and pivit ball in the bearing well. The re-wire my son performed also took care of a speed error that was noticable mostly on the trailing notes.
Resent purchas of a 2M Blue has also replaced the vintage EXCEL ES70e... Ok so I have a FrankenTT with all the parts it does sum greater as the saying goes,,, in reverse...lol Thing is I am quite happy and am moving on to my Amplifier projects, a pr. vintage HeathKit W4am tube amps.
