dshortt9 said:Do you have any sensitivity info or graphs?
measured response of the 1st set we had (in the 3-ways)
dave
dshortt9 said:Is the sensitivity in db/w or at 2.83v?
Good question... i didn't run these, a friend with LMS did. If i had to guess i'd say 2.83 V (so dB/2W)
dave
I think so too. Thanks for the info. I am going to use a push-push configuration for my project.
dshortt9 said:I think so too. Thanks for the info. I am going to use a push-push configuration for my project
Something like the Fostex Heil above? What are you thinking of for mid-bass? Active or passive?
DAVE
I bought 4 Klipsch 1089-av 10" mid-woofs that klipsch uses in the RF-7 and run up to 2200Hz. They are good for 96 db at 1 watt and use 90 oz magnets with ceramic-aluminum cones. I am thinking of placing one on the front and rear in a bipolar arrangement for baffle step correction, and using a 1st order series crossover of the proper Z to get a 12db/octave rolloff around 1000Hz. Hope to get pretty efficient speakers and good sound. I heard the woofers in the RF-7 and they are pretty darned good. Klipsch tries to run them too high and I don't like the sound of the Klipsch tweeter as much as I will like the Heil. This two way should be extremely transparent. I'll have to spend time tinkering with the crossover but that is always the case.
Any comments or suggestions are appreciated.
Those are pretty woofers, haven't heard them. have heard comments that maybe Klipch is a little optimiistic with efficiency. Will be very interesting...
at a 1k XO you may need to be a bit steeper than 2nd order.
dave
dave
Phase plugs back in stock -- Yew, Teak, Arbutus, Black for the FE103, Arbutus, Black & Teak for the 1354.
dave
dave
Tweeters?
Hi, Dave!
Any good (super)tweeters in stock?
I have seen the Ess AMT/Heil on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50597&item=5734906432&rd=1&ssPageName=WDVW
(are they the "real" thing?)
Do you have anything like them, or Raven, or suggestions?
Arne K
Hi, Dave!
Arne K
Re: Tweeters?
Some relatively good budget ones... another set of the Coral alnicos coming up (if they test fine)
That looks like new from the ESS factory... they have bumped the price abit, but i figure they are still VERY good value.
These go really low for a super-tweeter (i've heard of people getting as low as 700-800 hz)
Nothing used, and so far i've only picked up a single new driver for resale -- the CSS WR125. I am a Solen dealer, so can special order any of the drivers they sell (mostly Fostex to this point)
I have a pr of the Arum Cantus 2Gsi i picked up from Bob at CSS. I figure these are probably best value for a ribbon SuperT. At this point i'm likely to mate them with a pr of Jordan JX150 i have (active XO at 6-8k)
dave
Cobra2 said:Any good (super)tweeters in stock?
dave
It sure looks like ESS is selling some tweeter by them selfs via e-bay. I have had two pairs of the older versions of the AMT tweeters and compared them to the new ones. The new ones are defenitly better. The older ones I have purchased via e-bay sounded a bit crappy actually. I have replaced the diaphragms of 1 pair wich made them better but still not as good as the new ones. Still when I compare the new AMT's with a pair of Raven R2's then the AMT's have more guts but the Ravens sound much much more detailed in the top-end. I have gave up on the AMT's but still $300,- for a new pair is a bargain, just buy them.
Dave,
Your phase plugs for the FE166/167, they'll work with my FE164's, right? Isn't it basically just an earlier version?
leadbelly said:Your phase plugs for the FE166/167, they'll work with my FE164's, right? Isn't it basically just an earlier version?
Tony,
Sorry for not getting back to you yet on this. I do suspect that the 166/167 plugs will work on the 164. The voice coil only needs to be the same size, and as Fostex seems pretty consistent i would strongly suspect they are.
dave
Dave,
Can you supply phase plugs for Fostex FE 204?
I would be interested in some of those that are pictured on the first site of this thread.
It should be the same as for FE 206E I suppose. I don't know about the diameter of those for FE 206E, but for FE 204 they should be about 32,5-33mm diameter. probably more like 33mm.
Bartek
Bartek
zygibajt said:Can you supply phase plugs for Fostex FE 204?
The 1st batch of production 206/207 plugs are enroute to me right now. These should fit the 204.
Tim Forman did the beta tests, and he did some actual measurements. (production in red, stock in blue)
http://www.timn8er.com/fostex_fe207e_phase_plug_test.htm
Here in Yellow Cedar
These will be priced at $30 USD/pr + postage.
dave
What is the diameter of it?
zygibajt said:What is the diameter of it?
They came today and measure 1 5/16" (33mm) in diameter and 1 9/16" (40mm) long
I haven't gotten them up on the web site yet, but i do have an eBay advert up (they can be bought direct, the eBay advert just gives me broad exposure) ....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5777385746
dave
hehe...they are very nice...cannot say what i am thinking...planet 10, i think you
Could capture my mind transmission.... hehe.....very interesting.
But also pretty...i really like it.
try to capture.... if you smile you got it!
Carlos
Carlos
Re: hehe...they are very nice...cannot say what i am thinking...planet 10, i think you
destroyer X said:.... if you smile you got it!
I am now taking orders for the new CSS FR125S.
A thread on this driver http://www.diyaudio.com/forums/showthread.php?s=&threadid=59762
dave
dave
- More Vendors...
- Planet 10 hifi
- planet_10 hifi
