Planet Audio Anarchy 5000.1d
Agreed to look at a friend's amplifier. That should just be replaced. But anyway I removed all the power supply irfb3607's but this amp looks someone has worked on it. Used leaded soder which led to it to failer. Are these the OEM mosfets for this amp. Or can I just use 3205's despite the 55v 70v difference?
Board in all it's glory
oh god, well i had a decent drive signal, removed rectifiers, installed all new gate resistors, installed the 3205's, just got a clicking sound like its jumping in and out of protection, instantly checked for soder bridges, nothing. The output stage had failed as well one output wa broken off at the board, and shorted? i dont think the cost is worth the time
Never buy semiconductors from EBay, That was a great paragraph by the way perry. ok will do. So removed the failed outputs and rectifiers, with only the power supply it didnt run. all new gates 47ohm, new 10K to pull the gate down, all the diodes test good. there is a row of 22J100 capacitors that are semi melted. that in curcuit my fluke woulnt read Capacitance on? i did have the board powered up and had a ok gate signal>?
Same ic I was using perry. The original ic was failed. As soon as I installed this one the amp powered up and everything looked good, then small puff of smoke and the amp shut off. I was watching the current not board, so I didn't see where it came from. It will not turn on now
