planer or power tool?
I'm visiting my mom, and there are some things that ideally I'd like to trim-a sticking door in the basement, and basement windows that are very hard to open because they and their frames have been painted over so many times.
Do you think a planer would work better, or a power sander or such? I haven't priced planers, and haven't used one in a long time. One of my concerns is that while I can remove the door, I cannot remove the windows, which means holding them open while trying to plane. And the windows have turnbuckles and latches along one edge, so I ran run the planer hanging over both sides of the wood (the window edge is about as thick as a door FYI).
You plan to buy? A power planer is the optimum tool, but you'd have to have a lot of similar jobs to make it worth it. I'd go with a belt sander, much more usuable generally for projects, and more forgiving to learn to use.
The window sashes normally come out some way. If they don't, you can't clean-up all the way into the corner.
I doubt you want a power plane on sashes.
Maybe on the door.
It is amazing what a GOOD hand-plane can do.
I recently built-up a counter-top. To even the edges, I turned to my large Stanley hand-plane, even though I have a power-plane.
If you must buy a power-plane: I was asked to review a plane (in return for free product). Home Depot's WEN 8 Amp 4-3/8". Model # 6534 ($59). It cuts well, maybe not as precise as a high-buck tool, seems bigger than it needs to be, but never strained. I have some 23" wide pine slabs so I may get some use from it. They also have a 6 Amp 3-1/4" ($43) which is more reasonable for joists and doors. The blades are "not resharpenable"; you can buy them from Wen but if you are really whacking wood (bigger than a few doors) this may not be the way to go. Not saying you should buy it; but if you need a light-use plane this is fair value for money.
I have a Makita power plane that is available on Amazon for $150 (#KPO800K) it has adjustable depth of cut in 1/64" increments. You can also find one used for half of that or so. I used it to fit all of the doors in my house. You will want to first masking tape the outer faces of the door adjacent to the edges and measure/mark the areas that need material removed. The best time to do this is in summer when humidity is highest...if you do it in winter and get a good fit you're likely to have interference in summer when humidity causes the wood to swell. In summer conditions I would shoot for 1/16" to 3/32" clearance to the door frame.
I think of new metal planes as more like "kits" than products that are usable out of the box. The last time I bought one, it took a couple of hours to flatten the sole, sharpen the blade and breaker, and adjust the throat. Trying to use one that hasn't been tuned will be frustrating. How about a sanding block? Not as fast as a tuned up hand plane, but the learning curve is much shorter, and less likely to cause an "oh sh*t" moment than a power plane.
hand rasp-plane - Surform...
"Shaves everything but your beard."
Now sometimes easier to find in car-parts, next to the Bondo.
While Stanley (who bought the rights), and others, still push them to woodworkers, the stores favor sexier high-markup tools (like the power plane). OTOH the auto-body fixers want something that just works, cuts without gouging or clogging. My NAPA has a better selection than my Home Depot.
