The fostex designs look complex, but are all right angles and aren't that hard to build. Back loaded horns are the only single driver option I would recomend for the 108's. If you want something similar, but simpler check out the fe127, fx120, or fe167. These should all work in a simple ported box.
Joe
Joe
Hi Justpoor
Josephjcole is right. The Fostex box is the easy to do.
All the pieces are rectangular.
Other boxes are more complicated.
Fostex provides drawings that teaches as it is constructed.
If you interests I can send.
best regards Jaime
best regards Jaime
