Plan for Fostex FE108
The fostex designs look complex, but are all right angles and aren't that hard to build. Back loaded horns are the only single driver option I would recomend for the 108's. If you want something similar, but simpler check out the fe127, fx120, or fe167. These should all work in a simple ported box.
Joe
