Placement of power amp imput resistor
I recommend placing it on the tube socket if at all possible. This will apply its low pass filtering (allong with the tube's miller capacitance) to remove radio frequencies on the amp input AND picked up anlong the wire to the tube. But it is not very critical, and many amps work just perfectly without this resistor. I sometimes try to have the tube socket physically close to what drives it (either volume pot or input jacks) and then use the input resistor as the connection between them to save wiring.
I've always seen it on the input jack. Especially on old equipment, and I really respect the older engineers who designed those. The tube sockets are busy enough already.
Guess where I install mine.
-Chris
