PL4000.1D no audio output
I got a Planet Audio 4000.1D that had the power supply burnt but replaced all the 3205 and all 47ohm resistors and 4 of the smoothing Caps next to the speaker connection and all is good to go.
All the output FETS were good. Tested with Oscilloscope and everything is working.
Power at idle is 1.280v
All FETS are running warm not hot.
Turned all pots and switches back and forth over 100 times with no change to audio output.
Made sure my audio input and speaker worked.
Tested all transistors and Diodes on-board with multimeter set on Diode and to the best of my knowledge they all checked good.
Tested the 3w resistors on-board R25 and R26 but had Caps so couldn't get a reading. Lifted one leg and tested well.
I only have less than a year of repairing car amplifiers and can fix most but these with power and output working 100% but no audio output gives me the most trouble. I read Perry Babin Tutorial but he has so much info it's hard to remember it all. I think I just need to read it from start to finish 3 or 4 times.
Any help would be appreciated.
Sorry it's taken so long, I got my daughter her first car and I had to fix little things and get inspection ,tags and transfer title.
I tested for audio on all pins of the driver board and got nothing.
When I disconnect the power I get a pop from the speakers. I should have mentioned that at the start but just slipped my mind.
I have all FET clapped down on a rectangle aluminum bar and everything stays cool.
