Pioneer XR-P1500C CD Player problems
2 problems have developed with my Pioneer XR-P1500C stereo.
1) The CD tray won't rotate when I push the "Disc" button unless I physically lift the tray up. It's a 3 CD tray.
2) Frequently, the CD tray won't slide open when the "open/close" button is pushed.
I have removed the case, but don't see anything that might be causing these problems. The above also occurs when I use the remote.
I've tried removing the CD tray, but don't see how to remove the attached cable to completely remove it from the unit. Could this be a belt problem?
