Pioneer TS-C132PRS / TS-C172PRS: Best active Crossover Points ?
Hi, this is Christian.
I need your help with the 2-way Pioneer speaker systems TS-C132PRS and TS-C172PRS.
In Germany Pioneer Car audio components are not so polular and because of that I can´t get the information I needed. I hope someone of you can.....
I want to run these Speakers with an active crossover (Linkwitz-Riley, 24 dB) for a front system.
The original passive crossover from Pioneer has a crossover point about 1900 Hz. In my opinion this is very low. I only found a russian test of the 172PRS and a review at Crutchfield ("tends to muddy up the upper-end vocals when at higher volume. I suspect this is why the crossover transitions to the tweeter around 2,000 Hz. ...the tweeter is crossed over so low in the passive crossover that it can get a bit stressed....)
I don´t know if it´s important, the speakers will be installed in a Mercedes C-Class (W202), Tweeters positon: A pillar.
Can you tell me the best crossover point for each of the systems ?
Thank you yery much !!!
Best regards from Germany
Christian
1-inch car tweeter should be crossed over higher than 2 kHz - at least at 2.5 kHz, or better yet, at 3 kHz. Tweeters are identical in both systems.
Both woofers have rising frequency response, try the inductor (only) from the original passive crossover as an equalizer, if needed.
