I solved the problem 🙂
It was exactly same problem as "stephensank" described.
But i didn't know that the Cap wasn't needed so I moved it to other side as you see.
Thank you for quick reply and excellent guidance.
Great forum..
Hello i want to buy this recorder for playback use , seller described this exact problem spinning correctly recognizes toc plays correct yet no sound! I am wondering if this is a simple solution for a newbie like myself, is it only a matter of cleaning the board? What should i watch out for when i go look at the recorder in order to determine if it is possible to restore it or in the other hand it has to much leake?
First post! Hope you guys can help me
