Audiofanatic
Thanks for your advice. But there are no chips in my pds501 that have 60 pins.
CXA1372S has 48 pins, and one guy told me that i could use pin 26. Then to connect one inverter (7404) on that signal and that this would work.
I'll try.
guytou
Thanks. Send me anything that may help.
Thanks!
I'll try.
guytou
Thanks!
schematic
Hi Guytou,
He allready got the manual from me
Thanks for your effort.
Audiofanatic
guytou said:smario , i tried to send you a manual pdf , but failed(SMTP error) .
Your mail box maybe does'nt accept large files , since this one is 4Mo large .
Hi Guytou,
Audiofanatic
guytou
I've got PDS501 service manual from Audiofanatic. It was 4 MB and I recieved it without problems. I cleaned my inbox so that you could send it again or yust send it to msprah@yahoo.com (there is an inbox of 1GB).
Audiofanatic
Thanks for help.
I'll make this modification and write results.
Audiofanatic
Thanks for help.
Hi!
Could anyone mail me the Pioneer PDS502 schematic?
base@bin-dagegen.de
Many thanks in advance!!
Base
base@bin-dagegen.de
Base
If you are looking for Pioneer PD-S schematics look at the link I posted in a previous thread
service manual thread
using_e
using_e
Hi everyone,
I have Pioneer PD-S503 which has some problems with playing CD's. Sometimes spins cd and stops, but if it manages to read and you can listen just few seconds "sound" which is unfocused and with lot of (white)noise and stops again. There are two op LA6520 and one of them is getting hot gradualy. Cd player opens tray without problem. I try trimmer in laser pcb to adjust but, it seems this is not the problem...
Any idea, schematic, suggestions are welcome.
thank you
bekimh@gmail.com
thank you
bekimh@gmail.com
Pioneer
Hi Bekim,
i was hoping that you didn't adjust any trimmer but unfortunately you did, this will make the adjustment after replacing the new laser almost impossible if you don't have the adjusting schematic and manual. This means that the laser unit has to be replaced and adjusting this is a real problem, not to use the word (Almost) impossible by a DIYer.
The LA 6520 gets rather hot, this is normal and will work fine.
Just look for a service depatrment from PIONEER, not just a electronic shop and get it fixed. I'm not saying it's impossible to do it yourself, but almost if you don't have the time and equipment.
All the best,
Audiofanatic
Hi Bekim,
All the best,
Audiofanatic
- Digital Source
- Pioneer PD-S501 CD Player Schematic Wanted/Or Help!!
