Pioneer GMX-962
I will list you everything i have it will be more simple
K161
A1267
H945
FR91A
9014C
TL431
2931A
C1740
A933
C458
C1335
C461
A738
C1368
D882
B727
TIP125
TIP107
A1129
7812CV
7805CT
C3225
C2240
J103
C2308
C2655
A1020
when i tested it i had constant 12V on the collector and DMM on emiter and it worked??
there is no polarity ? wether 12V is on collector or emitter it will output 12v on the other when ground is applied to the base ??
cause looking at the diagram and for a PNP it would come in from the emiter and go out through the collector and i tested it the oposite and it worked...
i dont have to reverse the transistor
with the amp B+ and GND terminal on the right
on the board the base is on left collector in middle and emitter on the right exactly like the 2SA1129 if i have it face to me
I hate using mica to separate the collector from the heatsink .. to much risks it fails ...
would you have another replacement for P55NE06FP ... with a TO-220FP case :\
i dont care if i have to buy 6 again and waste the others... its safer in my head..
unless you say that it should not fail if installed correctly...
The TO-220 transistor is BCE. The small transistor is ECB. It has to be reversed.
The mica insulators are OK. The clamping system used in this amp is the problem. The shoulder washers are marginal at best. You have to make sure that the transistor is lying perfectly flat after it's screwed down.
The IRFIZ48 is generally a good substitute.
