Did you have another post on this amp? That photo looks familiar.
The Elektrotanya | This site helps you to save the Earth from electronic waste! site has the D9605 service manual.. The sub channel appears to be similar. There is a flow-chart that tells you some things to check for. The 500 series parts are what you want to be concerned with.
I think the IC is likely OK but I don't have a test amp that uses the IRS2092S (wrongly referred to as the IRS2902S in the pioneer SM).
If you have the tutorial, IRAUDAMP5, 7D and 9 in the semiconductor datasheets folder have basic information on this IC. If you don't have the tutorial, they are available online.
- General Interest
- Car Audio
- Pioneer GM-D8601
