Anybody out there did some good sound mods on the Pioneer DVD-656 player?
I find that the unit in its original form offers a lot of musical detail from CDs but tend to sound a bit harsh on the highs.
Appreciate it if you could share your experience and results in improving the sonic quality of what is already a very good piece of gear for the price.
Best regards,
Kenneth
Best regards,
Kenneth
General method.
You will notice that the general method of upgrading players is by modifying the following :
1. Upgrade the output stage opamps
2. remove or change output mute ( with a relay ) and better non
polar capacitors or remove them.
3. Improve power supply by any of the following methods.
* Better capacitors
* better regulators
* separate transformer for the analog section
4. Use a better system clock (Kwak clock etc )
5. Damp the cabinet top , bottom and sides
Cheers.
* Better capacitors
* better regulators
Cheers.
Power supply diodes (I dont know if yours has a linear, or a switched mode psu..) should be changed to Schottky - seems this can reduce treble roughness and harshness quite a bit.
Remove the feet and use 3 wooden cones, if you can get some. This will help transform the character to a more mellow, natural one (especially when combined with some damping).
A braided power cable, and/or mains filtering may also help reduce harshness, and grain, slightly.
The other mods suggested will probably improve it in many, many ways 🙂
