Hi my name is Paul and I've just joined.
For anyone who needs them I have several manuals/spec sheets on Pioneer component speakers of the late 60'S, they are as follows:
Woofers
PW-38F 15inch
PW-A30 12inch
PW-A25 10inch
PW-A20 8inch (This is for the coaxial speaker based on PW-A20 so cabinet is the same
Full range coaxial 2 way
PAX-A30 12inch and multi-cellular horn tweeter
PAX-A25 10inch as above
PAX-A20 8inch as above
PAX-20h 8inch as above
PAX-25B 10inch and cone tweeter no size given
PAX-20B 8inch as above
PAX-30G 12inch and horn tweeter
PAX-30M 12inch as above
Full range coaxial 3 way
PAT-20X 8inch with horn mid and ribbon tweeter
Full range single cone
PE-20 8inch
Mid range ( Squawker )
PM-100 multi-cellular horn
PM-500 horn
PM-12A/PM-16B 5inch/6.5inch cone type
Tweeter
PT-7 horn
PT-6 horn
PT-8A horn
Crossover networks
DN-21/DN-31 2 way/3way
Also 1 catalogue with all of the above plus others pics and specs only.
Anyone wanting copies please contact.
Woofers
PW-38F 15inch
PW-A30 12inch
PW-A25 10inch
PE-20 8inch
PM-500 horn
Tweeter
PT-7 horn
PT-6 horn
PT-8A horn
Crossover networks
The originals are not for sale but I can scan them and email.
Also I have a pair of speakers made up of PW-A25, PM-500, PT7 and DN31 crossover all still working they have been used for parties many times and made up the main speakers in my surround system they for about 20 years. The PW-A25's have had to be reconed once and new braids once in that time. Also Have 2 x PW-A30's that have had only the braids replaced, they were used once at a school with the above mid, tweeter and crossover useing a pro power amp rated at 200W RMS per channel. In the early 70's through to the mid 80's these were used as main speakers in my stereo system then used them in there own enclosure as subs only in large venues again with pro power amps rated at 250W rms, it was during this time they needed new braids. Now they are out of there cabinets stored away in the garage.
Hai Paul...
May I have the scan format for the pioneer component datasheet.. I have PT6L and PW251 which was taken from my old Pioneer CS-A25 Speaker System..🙂
Welcome to the forum Paul.
I have none of these drivers but am always interested in vintage drivers. If it was my collection i'd be scanning the works and making it available.
As is i'd ask to be cced any scan someone does request (i know al too well hoe much work it is to scan this many documents and then clean & prep them for distribution).
I'll send you an email so that you have my address.
dave
dave
good morning, I request please send me your speaker manual pioneerr PAX-30M
Woofers
PW-38F 15inch
PW-A30 12inch
PW-A25 10inch
PE-20 8inch
PM-500 horn
Tweeter
PT-7 horn
PT-6 horn
PT-8A horn
Crossover networks
Hi Paull,
I've a PAX 12-A, just one, so I want to make a mono full range LT for it, so if you, or someone have its manual, will be great! I only find out that the built in crossover was 3Khz, but Fs maybe 65 or 76Hz, even 100 hz. PAX 12 B is similar.
Hi Paul,
I appreciate your sharing documentation on some Pioneer speaker components. If they are still available, I would greatly appreciate any information on the following components:
PW-A30 woofer, PM-500 squawker, PT-7 tweeter and DN-31 crossover.
Thanks!
Bill
Thanks!
Bill
Yes, that little winky emoticon was for fun. I have actually been to the imposter Vancouver. It's only a 5 hour drive from its Canadian counterpart. It still surprises me that some people here don't know about the Washington city.
Pioneer DN-31 dividing network
I need to update the capacitors in this crossover and could use the spec sheet to find out the values needed?
- Member Areas
- Introductions
- Pioneer component speakers of the 60'S manuals
