Hello everyone,
I'm looking for the pin-out or datasheet of an M-Tek D4101DAG which is obviously a pulse transformer used to drive SPDIF 75Ohm lines. I couldn't find anything on the web about it, but want some data and the pin-out because I want to re-use the parts on a miniDSP nanoDIGI board.
Thanks for any help!
Winfried
Winfried
1 is input, 2 is inputs GND, I am sure of that. 3 seems to be the output and 4 outputs GND (for right phasing). You can put signal on the input pins and measure the outputs. The transformer seems a clone of the Pulse Engineering types. I think you better look for Murata DA-101C if you like known good quality.
