Ping: John Curl. CDT/CDP transports
I know that it appears to be forbidden, but I will side with the audio reviewers: John Atkinson and Bob Harley on this. They are more open to listening differences, and have worked on the problem for decades. We often share other listening opinions as well, such as extended bandwidth, etc.
1968 was a very good year for me: First, comp-sym input stage, design phase locked capstan servo, first met Richard Heyser, first extensive use of QuanTech noise analyzer, my first jfet reproduce stage for pro audio, etc, etc. But I did not stop there.
Bill, that is a $15,000 product! I can easily believe that that level of quality is important for best sound, but does everyone else here agree? I just don't want to pay that much for digital. Call me cheap, but I already have a $1200 Blue Ray player that is just OK. I could get better, but I don't think I will. I will just suffer with analog when I want, and suffer digital when I have to. '-)
Starting at post #28 on page 3 there is a lot of information for several pages on disc reading, eye patterns and error correction. Pay lot of attention to Anatech's posts.
http://www.diyaudio.com/forums/digi...s-long-gone-let-us-build-one-ourselves-3.html
The quoted section below is what I was basing my short little posts on.
From Post #32 in the above thread:
"The fact remains, the instant the C2 flag is raised (any of your Ex.2 stages), the original data has been marked as bad, it's over for that packet. The C2 "corrector" now does it's best to send data packets out that have a good CRC so the DAC can make an intelligent output level. But the data is no longer what was on the CD. All it has going for it is a data packet with a matching (good) CRC bit. The data is valid, not what was on the disc."
The "bit perfect" folks get this bit wrong every time. But I can see where the confusion comes from.
-Chris
And here is the whole of Post #32, in case you think I took something out of context and just cut and snipped.
"When we were taught CD service by several companies, they went into great depth so that we even understood the Reed-Solomon error correction. This is still the way CD error correction works, it's locked in to the standard. Those companies included Philips Teac / Tascam Revox and I'll assume that Yamaha was also correct since they agreed with everyone else. Denon was probably from Sony's technical services.
Where you might be getting confused is by considering the DSP output as a faithful decoding from the material encoded on the CD, but it isn't. Let me expand on that.
If your E1.2 and E2.2 is considered referenced to whether the data is valid or not, that would explain it. When the level 2 error detection is flagged, that means that level 1 failed, and that means the data is unrecoverable - period. Now, in the level 2 (C2in my world), the original data is discarded, make no mistake, it's gone. What happens in the C2 next is that, depending on the DSP programming, a previous data value is substituted, or an interpolation is made considering the previous values and the next valid value. Whichever action is taken, what comes out of the DSP chip is valid data, but it ain't the value that was stored on the CD unless by chance it was. Now, if the preceding data is bad, and the next data is also invalid, there is no choice but to mute the output in the digital domain. I think you are calling this step E3.2. But make no mistake, if the level 1 error correction fails, level 2 is concealment. It's not some miracle of technology that pulls the corrupted data out of thin air. The level 1 corrector already did the Reed-Solomon thing and it didn't work. The distributed data was corrupted as well (at least the CRC was).
The "bit perfect" folks get this bit wrong every time. But I can see where the confusion comes from."
Again, if your CD player isn't broken (Chris is a repair guy, and a damned good one) or you haven't been doing mindless mods, you get an interpolation error once every several hours of playing. I've done the experiment as have many others. We all get the same result.
This just isn't a problem.
Yes, I agree it really isn't much of a problem because we always hear the music.
The fact that the audio data is bad in the first place hardly has anything to do with the CD standards.
Of course it doesn't.
Where between the analog input and SR encoding can the data get changed?
Only the ADC?
Good stuff stvharr. THx. Make a lot more sense than-- it comes out exactly as the input intended. That sounded like magic.
THx-RNMarsh
This is also what I suspected from the basic concepts.
Reality notwithstanding. I see SY and Chris are wrong because they are not in the right posse. Did you ever think to find out how many CU (uncorrectable errors) occur in normal use of a decent CD player? Folks have actually done this. BTW everything I read says the original comment is wrong C2 errors are not guaranteed to be uncorrectable CU are. E Brad Meyer has published some results using a Plextor professional CD debugging tool but he is definitely in the wrong posse.
From a professional CD mastering service.
CD replicators consider a disc with an average of 220 C1 errors per second, "a good quality disc." Typically, our masters
average less than 1 C1 error per second with absolutely no C2 or CU errors. We have our own standard which states that in
addition to no C2 or CU errors, we will not ship any disc that averages more than 2 C1 errors per second. That's .009% of the
maximum allowed for a good quality disc. This provides you with an excellent master of the highest quality. If you're going to
have your CD professionally replicated, there is no substitute for a quality master provided by a professional mastering facility.
While mastering is about EQ, dynamics, song levels, etc., it's also about providing you with a low error master that will be
accepted by CD replicators. We test each master for errors and provide you with full documentation on it's quality.
The fact remains the idea that CD's in normal use contain enough error interpolations to have a sound is simply nonsense.
