pig in a poke Nirvana T-S parameters - where do Super 8's run?
grabbed a stamped pair from auction - seller didn't measure - where are Super 8's running for Fs, Qts and Vas? My super10's Qts ~0.42, Fs~49 - hope Super 8's qts comes in below 0.38
have AN users compiled listings of parameters?
Averaging what you have:
48.45 Hz Fs
2.922 Qms
0.26 Qes
0.238 Qts
7.434 ohms Re
0.128 mH Le
Published:
11.663 g Mms
8.8 cm radius = 243.285 cm^2 Sd
Calculated average:
Vas = 78.604 L
BL = 10.0755 N/A
Cms = 0.00092521 mm/N
GM
Hi there Freddi: You now have four sets of T/S data for the AN super 8's, manufacturers, your two measurements and GM's average of your measurements. What values will you use to design the enclosure for the two AN's? Hope you will post the Vas test data, so the community can add this to the general knowledge of speaker measuremnets. Everything manufactured has tolerances, even WT3's and computer equipment used in these tests, as well as the drivers themselves. So how do we know the "actual" calibration of our test equipment/set-ups? ...regards, Michael
Don't know. But I find that more mass give me more consistent results. You might try that.
Too much can lead to the curve cratering as the suspension starts getting tweeked... i use 25g (a ring of ductseal) on the 6-8" drivers. hard to keep nickels on the cone when it is held cone facing horizontally (facing up will not give accurate results).
dave
