Hi Greg
Does Piano plus support include the setting of the subwoofer cutover frequency to zero? As I don't have a sub I want to use the dual DACs without a 80hz cutover.
Cheers
Nick
Hi NICKEL,
I don't have a Piano DAC so can't test it, but I imagine it is a function of the driver developed by Allo, so maybe its best to ask over in the Allo Piano thread.
regards
How to set this DAC with Raspberry Pi 1B + PiCorePlayer 3.11 ???
not work - select Hifiberry DAC...
please help....thnx....
hi otava5,
Did you add the 8 port connector to your Raspberry Pi B?
Please post a picture of your Raspberry Pi.
regards
@moderator: OK
After connecting the 8pin connector, it works ... thanks
Thanks otava5 for posting your solution, it will help others in the future.
regards
It can be done with the rpi3 on board wifi.....if your USB wifi supports the standard hostapd, then it should work too. Shoot me a PM, and I'll send you some instructions......
Sorry to thread necro, but I am really keen to do this as well. Could you share your how to for pCp so I can do this to (also on a Raspi 3)?
piCorePlayer 3.21
The pCP team has released a minor update, but has some key new things that some have really been waiting.
Here are the major changes.
- Kernel 4.9.35, Firmware 2017/06/30
- Supports new Allo DigiOne, MiniBoss, and updated PianoPlus driver to support Dual Mono/Dual Stereo
- Added Piano Plus alsamixser controls to Audio card Control Page
- Multiple USB and Network Mounts.
- Wifi should now work in the Audio Optimized Kernel
- If you have a RPI3, you can now run pCP from a USB memory card. - You may need to configure your RPI3 to support this, Raspberry Pi Bootmodes You will have to increase the waitusb= value in cmdline.txt
- Squeezelite packages in image updated to latest.
- Touchscreen kernel module package, now include fbtft and other kernel modules for other screens.
- Fixed AudioCore Touchscreen kernel packages for missing backlight dependency.....(separate Backlight-xxxxx.tcz is no longer required.)
New Images and Insitu_update packages are available now. News - piCorePlayer
- PC Based
- piCorePlayer = piCore Linux + Raspberry Pi + Squeezelite
