Picked up a load of working vintage Threshold gear
Hey folks,
I Picked up a NS-10 preamp, two M1s, 400a and a Cas-2 all for $650.00 All of this stuff is original and in good working condition. All they need is the electrolytics replaced and some minor repairs.
I have a few questions:
NS-10:
1) The NS-10 had the transformer replaced with, I'm told, one that is of the same specs. I see that the original one manufactured by Signal transformer DPC-24-450 is still available from Digikey. If this is not the transformer in there, should I replace it again with the correct one, or is there any benefit to going with a higher VA rated toroidal type?
2) How well will this preamp NS-10 mate with the "First Watt" F5 which I intend to build?
400A:
3) The 400a is very nice, but, has the wrong feet and the front panel bolts are missing. Where can I get the original (4) bolts?
4) The 400a has very good condition original emiter resistors. I just did a total rebuild on another 400a that was totally destroyed and all the emitter resistors were split or broken. I would stay with these original resistors if I were keeping the amp. I loaned my son the 400a I rebuilt and will swap it back with this one as the rebuilt one is of my best work and what I consider "show quality". I'm concerned about the original emitter resistors, as, my son is running low impedance Magnepans. Should I change them?
M1s:
1) The seller told me one of the M1s did not sound as good as the other and he thought there might be a problem with it. It doesn't have much circuitry in it to fail. Is there a comon failure with these? Should I replace the Tantalums? My understanding is that, Tantalum caps don't fail due to age. Is that correct?
CAS-2
Comment - All I can say, is, I never knew this amplifier existed. What a great amplifier it is! This thing is very well made and sounds great!
I'm attaching photos of my 400a rebuild and all the great vintage NP stuff I just picked up. I have some cool fix's for the 400a in the photos you might like. The rebuilt 400a says "cascode" on the glass and the 400a I just picked up does not. Is the one without "cascode" not printed on the glass different, or was it just printed on the newer models?
Gary
Hi Rayma,
I restored and updated a Superphon Revelation Basic preamp for my son and in the upgrades reommended by Stan the original designer was a much larger toroidal transformer. These transformers were not poular in the 70's like they are today.
Gary
Hi rayma,
I agree, I don't make changes that are not reversible. The guy put holes off the 4 corners of the transformer on the PCB to accommodate two tie wraps. I don't believe there is any traces there but still unfortunate.
Gary
Hi rayma,
The transfomer was a drop in replacement. He added the tie wraps to further secure it. He said that it broke off but there is no damage to the chassis from impact. I think I looked at him like he had two heads. I said, what? you replaced the transformer??? Anyway, the holes are clean and look factory. I had to view several photos of other units to verify that they were not.
Gary
Well, you're in the right place, with the man himself available for input.
I have a feeling I was way younger when you were way younger. Back in the day, looking at a Nakamichi TA4 I was talked into a back-door deal on a modded Hafler, which thirty years later brought me to DIYaudio to repair/ rebuild based on the Bob Cordell design, and suddenly I'm in Nelson's back yard and have now built some of my dreams, i.e. the Aleph 60s...
And yeah, there's a CA5 and a PA5 in the house, serving daily duty. Listening to the PA5 right now, as a matter of fact as the kids have the Alephs in the family room serving up the incredible sonics of Lego Lord of the Rings games. :cheers:
My brother lives and dies by his PA7 and his collection of PA 5s, Pa5-2s (though I lent him an Aleph J and he's getting it). PA7s, last I checked, were running $1500 or so. So, for the price of building my own amps, I could have a PA7... but there's joy and pride in building your own and doing what you've done, which is rescue a piece of history.
Good on you!
Good on you!
Nice to have a collection of Nak's. I have two AV10's (not a N.P. design) and a OMS 7 cd player. I have a massive collection of Celestion SL line of speakers. I have the whole line plus the 100, 300 and the System 6000. As a kid, I couldn't pass by a broken TV on the side of the road. I would repair it and sell it. As a challenge, I went around to all the TV shops and took in all the stuff they couldn't fix, then, go back and tell them what was wrong with it. I love to buy all the audio equipment I dreamed of, (broken), and restore it for friends & family.
