I have seen a few different ways this has been done. I am using 2 .1 ohm resistors on my power supply. Nelson Pass has done this by putting them in series between the middle of the cap bank per rail serial to the rails polarity - so if it has 10 caps on the positive rail they would be between c5 and c6 on the positive side and running parallel before c6) I have also seen where one resistor was used in the middle of the cap bank on the rails polarity and then the second resistor bridging both the pos and neg after the last cap in the bank. What is the better of the 2 options I need to finish my soft start and trigger system before I can test my amp and a purchased amp module but I figured while I am waiting on parts I may as well build a bunch of power supplies - I can always leave additional traces on them but wondering the differences between the 2 and imagine putting a resistor across the last cap would also limit the capacitance?
