Can you fix my posted photos? They were ok at first, several weeks, but now they have shrunk down to the size of a dot!
see an example here.
http://www.diyaudio.com/forums/clas...ipath-board-tc2000-tp2050-60.html#post1952578
I have since started attaching them with thumbnails and those are working fine.
I'll look into this as soon as time allows. There are some other glitches with the image processing I need to fix as well - it's perhaps a GD versus ImageMagick thing.
Photos still shrunken
If you are able, Can you take a quick look at these posts in the Sure 2X100 thread to see why my photos, which were displayed properly for several weeks the same way that they are in my gallery, suddenly shrank. It is as if the code has dropped 2 zeros off of the size. You can still see them as a dot at the bottom of the posts which actually turns into a bigger dot when you click on them to enlarge. I have since switched to posting photos as an attachment which is working fine.
http://www.diyaudio.com/forums/clas...ipath-board-tc2000-tp2050-78.html#post1990135
http://www.diyaudio.com/forums/clas...ipath-board-tc2000-tp2050-71.html#post1970621
http://www.diyaudio.com/forums/clas...ipath-board-tc2000-tp2050-69.html#post1967513
